This plugin allows you to View JOB Files from inside SheetCam. Unzip the file into the SheetCam plugins directory.
The plugin assumes that your JOB file are in your JOB directory. From the plugin you can change to other drives or directories to select a file. When you see the file you want click on it. From there you can just use the UP and DOWN key to run through the list.
Not only can you view the JOB file but when loaded it is ready to process in Sheetcam. Apply your operations Post and you are ready to cut.
TP
