Scam Gcode Veiwer
Here is a new plugin that lets you Veiw your Gcode files.If you are like me you have 1000 files . You remember what it is it looks like BUT can’t remember what you called it. This works like the other veiwers.
Just unzip it into your plugins directory then restart Scam. It will appear under Plugins menu.
(:wink: TP
Because of a Quirk in Scam you have to click on a message box each time. Hopefull Less will get that fixed .
(:wink: TP
I tried out your G Code viewer plugin, unfortunately when I click on it in the plugin’s menu, it brings up the DXF viewer. Looking at the LUA file with notepad, the Dxf viewer and the G Code viewer look to be almost identical.
Thanks For the catch on the FORM NAME. I forgot to change it. Yes the code is similar but performs different functions.
Here is the updated PLugin with the correct form name in the screen veiw.
