Scam DXFview
This plugin allows yoou to View DXF Files from inside SheetCam. Unzip the file into the SheetCam plugins directory.
The plugin assumes that your DXF file are in your Drawings directory. From the plugin you can change to other drives or directoryies to select a file. When you see the file you want click on it. From there you can just use the UP and DOWN key to run through the list.
Not only can you view the file but when loaded it is ready to process in Sheetcam. Apply your operations Post and you are ready to cut.
(:wink: TP
Can anyone upload this again please?
Was going to give it a try.
