Scaling part inside Sheetcam
Les…
Is is possible to scale a part up or down inside Sheetcam. Yesterday I had to cut the same part in different sizes and ended up scaling the part in CAD, importing each one and creating a separate job file.
It would be very convenient to be able to just scale the part in Sheetcam and have the tool paths regenerate. I looked around a bit and didn’t see anything that looked like scaling settings.
You can’t scale the part in SheetCam however you can scale the drawing when you import it. In the box that appears when you import a file you should see an option to use a custom scale.
Does it still no scaling inside sheetcam?
With DXF DWG there is no problem, but it would be useful with SVG files.
