Excuse me if I’ve asked this before, but I couldn’t find the post if I did.
My scribe mount is such that while in use, the plasma torch’s tip is higher than my rapid clearance setting of 25mm. But the post will add the scribe offset to the rapid clearance amount. This means that the torch raises during plate marking rapid moves even though the M09 command raises the scribe tip higher than the torch tip.
Is there a way to not add the scribe Z offset to the rapid clearance during use of a tool number greater than 100?
If your scriber is fixed to the same axis as torch and you trying to disable z axis moves on scribe rapid moves,
then CandCNC post I am using has it covered.
Check these sections of the post - see how they solved it, maybe it helps to fix your post…
--this value when set to "true" will set the Z to lift to rapid height between paths when using the marker tool.
--if false it will not lift the Z between paths but will at the end
markerZ = false
function OnRapid()
if(endX < 1e17 and endY < 1e17) then --don't update the distance moved if X or Y are unknown
local len = math.hypot((endX + offX)-currentX , (endY + offY)-currentY)
dist = dist + len
post.ModalText (" G00")
post.ModalNumber (" X", (endX + offX) * scale, "0.0000")
post.ModalNumber (" Y", (endY + offY) * scale, "0.0000")
if(toolClass == "MarkerTool") then
if(firstRef == true) or (finalCut == true) or (markerZ == true) then
post.ModalNumber (" Z", safeZ * scale, "0.0000")
finalCut = false
else --this is not a marker tool
post.Eol()
function OnPenDown()
if (firstRef) then
Reference()
offX = scriberX
offY = scriberY
offZ = scriberZ
if (offZ > 0 ) then --put in the Z offset height if it the first scribe after a ref
post.NonModalNumber(" Z", offZ * scale, "0.0000")
post.Eol()
post.ModalNumber (" X", (currentX + offX) * scale, "0.0000")
post.ModalNumber (" Y", (currentY + offY) * scale, "0.0000")
post.Eol()
else --not a ref move
if (markerZ == true ) then --put in the Z offset height before the scribe after the rapid
post.ModalNumber(" Z", offZ * scale, "0.0000")
post.Eol()
post.Text(" M08\n")
else --tool is not marker tool
if(dist >= refDistance) then
dist = 0
Reference();
post.NonModalNumber(" Z", pierceHeight * scale, "0.0000")
post.Eol()
if (preheat > 0) then
post.Text ("\n G04 P")
post.Number (preheat,"0.###")
post.Eol()
post.Text ("\n M03\n")
if (pierceDelay > 0) then
post.Text (" G04 P")
post.Number (pierceDelay,"0.###")
post.Eol()
thcstate = 0
if(dthcOff > 0) then
ThcOn()
post.Text (" M22 \n")
