HIYA LES, Wishing you and family a happy holiday(![]()
Sometimes S_cam misses a small closed segment. The segment will be correct and has enough clearances BUT it only does the leadin/out on the segment but it does NOT cut the entire segment.
NOW if I go back and just select that segment and reprocess that segment it always will do it will correctly do the entire path the second time around.
This is just a hit and miss thing that pops up from time to time. At first glance it looks correct as you see the tell tale leadin/out BUT when it does not cut you realise what it was and have to go back the the JOB file and redo that segment. It is always correctable you just have to learn to verify the entire cut before it leaves the table(
or learn to reset and reburn the problem areas.
thanks (
TP
http://www.forum.sheetcam.com/viewtopic.php?p=10860#10860
