Hello, for a lot of years I use Sheetcam in combination with UCCNC and Neuron. Top combo.
The thing that bothers me with rules and Sheetcam is how to give priority to a rule instead of another. The problem now is that when cutting holes, the rule for corners is aplied. Only when corner-rule is disabled then the hole-rule pops up. I think it is a matter of priority between rules. Am I correct and how is this organised?
Thanks in advance.
Top product, thanks.
Generally the rule with the lowest feed rate wins. If your corner rule has a lower feed rate than the hole rule, the corner rule will have priority.
If you need more control you can put the holes on a different layer then use a different rule set on that operation. Note that if you have a rule set selected in ‘Always apply rule set’, that rule set will be combined with your operation’s rule set.
Nope, feedrate has no influence.
Different layers is to much work. Workflow is super. 3D cad, flatten to dxf, import in Sheetcam, shortkey crtl-L for plasma, crtl P for postprocess, I walk to plasmacutter, zero and start. Super! It is difficult to make less steps. More is not the plan.
Where could this go wrong?
Played a little with the rules, sort of ok now. Every day a little better. Super programm thanks. Just worried I missed something.
