rule sets
Right now, we’re able to always have a rule set running.
Would it be possible to specify on what this whole rule set is applying?, lets say, holes smaller than 3/4"
Problem i have right now, rules feature is so good, in a rule set, i say 50% of speed on smaller holes, but i also have commands on start and finish.
So i cant use the rule set on exterior cuts, so i have to put holes on a different layer.
thank you
One option would be to put the outlines on a different layer. You could use a different rule set on that layer.
If you use the ‘start code’ and ‘end code’ for your small circles rule it won’t affect larger outlines.
