Rotate work and table view
Hey Les,
Is it possible to rotate the main screen view so that the y+ direction is to the left and the x+ axis direction is up? We have a machine that is set up this way from the operator station for some strange reason and it is always a mindf*** to rotate it in my head in sheetcam. It’s just rotated counterclockwise 90deg.
Just wondering if this is possible or i need to keep turning it in my head
I think (never tried it) but you could change the axis in the post processor to spit the gcode out flipped 90 degrees… so you could work on it as you view the table and get it to spit the gcode out 90 degrees rotated…
post your post processor and I’ll edit it for you it you want… it may work…
