Rotary Plasma Plug-in
I am playing with the rotary plasma plug-in on a Fanuc milling machine using a Rotary Mach 3 post processor. The plug in works great after some minor code editing for radial milling or engraving. I wanted to know if there is a way to only show one layer in the rotary simulation mode. When the simulation is run, it shows all layers, but correctly machines the selected layer. It can be a little confusing when all the layers are wrapped around a circular object and you only need to view the post processor of one layer.
That is a very good point. I’m afraid SheetCam you can’t do that. I’ll add it to the to-do list.
