Is there a way I can replace a part that I have made changes to so that I don’t have to start over with the layout
If you have a drawing that already has cut operations set up you can just do import drawing and import the new drawing & it’ll swap the drawing out without removing the cut operations but then you’ll just have to re-put the features of the drawing on the correct layer.
Thanks it helped me a lot so I only had to adjust the duplicates a little bit they kept their rotation
