Hey!
In my worfkflow there is often a need to make slight modification/error fixing to my drawings.
As i do now: New job (don’t save - ok) new part (and choose the part with same filename).
Is not a big deal how it is done now, but would it be a lot of work to make a button “refresh drawing” that simply loads the same drawing again and applies the same toolpaths allready generated? would make my work much smoother.
Use File->import drawing. That keeps all of your operations and just reloads the drawing. SheetCam can even automatically reload the drawing. Go to Options->plugin options->autoload. Turn on ‘enable autoload’ and set the delay before loading to 1s.
Now whren you modify the drawing and save it SheetCam will pop up and sk if you want to reload the drawing.
How long has autoload plugin been available? I must not be paying attention to the update notes (or didn’t realise the significance of this until now).
