Re:unwanted start points
Hi. I am having problems with sheetcam.I am importing DXF files from Corel X3 and the file gets extra start points.How can I remove them or what am I doing wrong?
The most likely reason is that your lines don’t join up properly. Make sure View->show segment ends is turned off and View->show path ends is turned on. If you see any white dots on your drawing, zoom in and you should see where the lines don’t join up.
Belated thanks Less I will try that.Allan
Belated thanks Les I will try that.Allan.
