This will create a directory “plasma” which holds it’s own toolset and configuration file. Post processor file is still stored with all other post files, but the separate config file holds that info, too.
Yes, that is the correct way to do it. Here are some slightly more detailed instructions:
Make a copy of the shortcut to SheetCam and rename it. Right-click on the shortcut and select ‘Properties’. In the ‘Target’ tab the Target should be something like this:
“C:\Program Files (x86)\SheetCam TNG\SheetCam TNG.exe”
where myProfile is a name for the profile. The first time you use that shortcut it will copy your original SheetCam settings to the new profile. From then on any changes you make to that profile’s settings will not affect any other profiles you have set up.
