Less, I’ve spent the better part of today trying to use parts with some really strange results. I overcame the naming issue my manually entering the part name vs the drawing name when I did the post.
Where things go bad is when you click the check box in your parts list. It changes the operations to the part you clicked on. You then have to click off the previous part when then selects that set of operations. Back to the new part and select the words and the operations are back. There seems to be no synchronization between the words and the check boxes.
One other issue is that when I was setting up the part, I would hide all layers of the drawing that didn’t apply to that part. After getting all the operations and layers sorted out, I closed and saved the job. When I open the job again, All layers are on no mater which part you try to select.
In the next dev version you will be able to disable the auto naming.
The operations shown will always be the operations for the selected part. Clicking on a part will select that part. Changing the part’s name will not affect it’s operations in any way. The name is just for your convenience.
Yes, disabled layers are not remembered with the job. I’ll look into making them be remembered.
