Rapid rate
Most likely its in front of my eyes but I cannot see it!
Where can I set the rapid feed rate? The tool moves at the same speed on G0 and on G1/G2/G3 moves!
Rapid speed is controlled/limited by your machine, not SC. Make sure you are not in dry run or have your rapid override turned down for starters.
N0010 G20
N0020 F1
N0030 G53 G90 G40
N0040 G00 X0.5000 Y0.0000
N0050 G38.2 z-1.969 F19.685
N0060 G92 Z0.0
N0070 G00 Z0.0591
N0080 G92 Z0.0
N0090 G00 Z0.2000
N0100 M03
N0110 G04 P1.0
N0120 G01 Z0.1000 F600.0
N0130 Y5.0000 F30.0
N0140 M05
N0150 G04 P0.3
N0160 G00 Z1.0000
N0170 X1.0000 Y0.0000
N0180 G38.2 z-1.969 F19.685
N0190 G92 Z0.0
N0200 G00 Z0.0591
N0210 G92 Z0.0
N0220 G00 Z0.2000
N0230 M03
N0240 G04 P1.0
N0250 G01 Z0.1000 F600.0
N0260 Y5.0000 F40.0
N0270 M05
N0280 G04 P0.3
N0290 G00 Z1.0000
N0300 X1.5000 Y0.0000
N0310 G38.2 z-1.969 F19.685
N0320 G92 Z0.0
N0330 G00 Z0.0591
N0340 G92 Z0.0
N0350 G00 Z0.2000
N0360 M03
N0370 G04 P1.0
N0380 G01 Z0.1000 F600.0
N0390 Y5.0000 F50.0
N0400 M05
N0410 G04 P0.3
N0420 G00 Z1.0000
N0430 X2.0000 Y0.0000
N0440 G38.2 z-1.969 F19.685
N0450 G92 Z0.0
N0460 G00 Z0.0591
N0470 G92 Z0.0
N0480 G00 Z0.2000
N0490 M03
N0500 G04 P1.0
N0510 G01 Z0.1000 F600.0
N0520 Y5.0000 F60.0
N0530 M05
N0540 G04 P0.3
N0550 G00 Z1.0000
N0560 X0.0000 Y0.0000
N0570 M05 M30
Thats the export of the grbl post processor. There is no Fxxx on the G00 moves. Correct me if I am wrong, but I have the impression that at the above example the G00 will move at the speed of the last Fxxx value that was given, either it was G01 (or G02 etc) right?
I am not familiar with grbl.
Normally there is no feed rate associated with a rapid move, which is controlled by the machine/control.
Maybe someone familiar with grbl could help.
G0 tells the machine to move as fast as possible. You don’t define a rapid feed rate in the code. in The case of grbl the rapid feed rate is defined by the configured maximum rates. This page may help http://www.diymachining.com/grbl-feed-rate/
