I am not sure if this is already available or not as I have not been able to find it.
Recently a new feature was introduced to Universal Gcode Sender, and that was to use the “send from here” feature in case a problem developed in doing a process. I actually asked for the feature to be added and found that several others in the past had also asked for that feature, and now it is available.
While using it for plasma cutting, which is my concern, I found that there was a need to add something in the gcode generated by SheetCam that would make it easier to find where to start from here for the failed process.
I think it would be possible, if not already available, to use the post processor file to generate a heading for each process so that it would be easier to locate in the gcode file. I am not sure how to go about this myself, so I thought I may ask here if that is possible or already available.
Sorry, I missed this post. Yes, the post processor can be configured output the operation name. What post processor are you using?
firstPierceTime = 0 --this is an extra delay added to the first pierce as needed by some machines
function OnAbout(event)
ctrl = event:GetTextCtrl()
ctrl:AppendText(“GRBL plasma post processor\n”)
ctrl:AppendText(“\n”)
ctrl:AppendText(“Generic plasma post for machines with or without THC\n”)
ctrl:AppendText(“Modal G-codes and coordinates\n”)
ctrl:AppendText(“No comments\n”)
ctrl:AppendText(“M04/M05 turn the torch on/off\n”)
ctrl:AppendText(“Incremental IJ\n”)
function OnInit()
if(scale == metric) then
post.Text (" G21\n") --metric mode
else
post.Text (" G20\n") --inch mode
firstPierce = firstPierceTime
function OnFinish()
post.Text (" M05 M9 M30\n")
function OnRapid()
post.ModalText (" G00")
post.ModalNumber (" X", endX * scale, “0.0000”)
post.ModalNumber (" Y", endY * scale, “0.0000”)
post.ModalNumber (" Z", endZ * scale, “0.0000”)
post.Eol()
function OnMove()
post.ModalText (" G01")
post.ModalNumber (" F", feedRate * scale, “0.0###”)
post.Eol()
function OnArc()
if(arcAngle <0) then
post.ModalText (" G03")
else
post.ModalText (" G02")
post.NonModalNumber (" X", endX * scale, “0.0000”)
post.NonModalNumber (" Y", endY * scale, “0.0000”)
post.Text (" I")
post.Number ((arcCentreX - currentX) * scale, “0.0000”)
post.Text (" J")
post.Number ((arcCentreY - currentY) * scale, “0.0000”)
post.Eol()
function OnPenDown()
if (preheat > 0.001) then
post.ModalNumber (" Z", cutHeight * scale, “0.0000”)
post.Text (“\n G04 P”)
post.Number (preheat,“0.###”)
post.Eol()
post.ModalNumber (" Z", pierceHeight * scale, “0.0000”)
post.Text (“\n M04 M8\n”)
if (pierceDelay + firstPierce > 0.001) then
post.Text (" G04 P")
post.Number (pierceDelay + firstPierce,“0.###”)
firstPierce = 0
post.Eol()
function OnPenUp()
post.Text (" M05 M9\n")
if (endDelay > 0) then
post.Number (endDelay,“0.###”)
post.Eol()
function OnDrill()
OnRapid()
OnPenDown()
endZ = drillZ
OnMove()
OnPenUp()
endZ = safeZ
OnRapid()
Add this code:
function OnNewOperation()
post.Text (";Operation: ", operationName, "\n")
Tried it out and it works perfectly, thanks Les. ![]()
