Problems with working under different operating systems
Hello.
I ran into the problem of processing work with both a post processor and a post processor under different operating systems. What to do?
I run the test on Windows and LinuxCNC Debian. The result of G-code is different.
I am attaching files of the post-processor, work, and various G code files.
The LinuxCNC ARM Tube postprocessor is the same LinuxCNC plasma rotatif, but containing my revisions.
SheetCAM on Linux is 7.1.20 ver, SheetCAM on Windows is 7.0.21 ver
The difference is visible after line 11 after # = 1
Is there any way to solve this?
Regards, Dmitry.
Square pipe test.job (40.9 KB)
Square pipe test(windows).tap (3.48 KB)
Square pipe test(Linux).tap (3.35 KB)
Here I added only the postprocessor file, since the system does not allow adding more than 3 files.
LinuxCNC ARM Tube.scpost (6.76 KB)
Sorry there was a mistake. Post processors varied across operating systems.
However, there are some questions. For some reason, when executing function OnRapid(), the following sequence appears in the G code:
G0
X126.7000 Y-4.3619 A0.0000
Why does a line break occur?
Regards, Dmirty.
Sometimes OnRapid can be called when X,Y,Z,A axes have not changed or have only changed by a tiny amount. In that case it will just output “G0”. On the next call to OnRapid, it knows that G0 is active so it does not output G0 again.
