Hello. We are cutting a 40x40 mm profile. We are using RotaryPlasma plugin for SheetCAM v7. We have a problem with setting the torch height. When we zero the torch on the surface of the profile, it rises by 37 mm. It’s as if we had to zero the torch from the center of the profile.
That’s correct operation by sheetcam RotaryPlasma plugin, torch (Z0) zero is center of rotation by default. If you want surface, then see this post processor- Post Processor Example w Custom Options popup window - #13 by sheetcamCS2
