Problem SheetCam TNG Development
Hola
Me ha surgido este error la importar un DXF al SheetCam TNG Development me ha convertido estas lineas en curvas
Como lo puedo solucionar ?
Hello
I got this error when importing a DXF to the SheetCam TNG Development has turned these lines into curves
How can I solve it ?
Corte campana.dxf (11.4 KB)
Este es el trabajo en SheetCam TNG Development
Corte campana.job (16.7 KB)
This looks like a detail reduction issue. Go to Options->application options->drawing import and reduce the arc fitting tolerance. Now reload your drawing. If you still have problems, reduce the arc fitting tolerance further.
Gracias Les por su respuesta pero ya lo había probado pero no funciona debe ser algún problema de SheetCam TNG Development porque si lo abres en SheetCam TNG no da ese error.
Thank you Les for your answer but I had already tried it but it does not work it should be some problem of SheetCam TNG Development because if you open it in SheetCam TNG does not give that error.
Set ‘minimum segments for arc fitting’ to 10 or set the arc fitting tolerance to 0.
OK
Gracias
