hay there i love sheetcam so far how ever i cant really use it so well i have an older hpgl style router the hpgl 3d post seems to work but the
Z hights are all wrong and the feed rate is not being sent trough and i cant seem to find the ONsetfeedrate part of the post
i have a post for desk proto that is so simple but works amasingly
all it has is for 3d moves=
ZM x,y,z;
set feedrate =
VS#;
rapids = PU x,y,z
no AA comarnds used and works like a charm
the AA in the HPGL 3D post work ok to but for some reson if i program
something to say cut at 3mm it will only cut at about 1.5 mm
hpgl scale is good ive cut a shape and mesured it and its perfect
could you please re work the post for me i have spent meny hours trying to do it but i am afraid i dont quite understand how sheetcam posts are worked
i allso need to remove the tool change from the post so regardless of the tool used in sheet cam the post still reeds SP2 an not related to the tool used in sheetcam
your help would be verry much apresheted
thank you heaps
