We are using GRBL1.1h with USB-CNC plasma.scpost. A friend set up a breadboard using an Arduino and drivers and it works! We have built a more permanent copy in a case using identical parts and software and it doesn’t fire the plasma to cut-but the table and torch move correctly. We have recently tried adding S1000 to the M03 torch-on command lines and the torch cuts correctly. Can you tell us how to update the postprocessor code to include the S1000 command to the M03 command lines?
Do you need S1000 with the M3 or just at the start of the code?
We need to S1000 command to appear on the same line as every M3 command
It’s very simple to edit the postprocessor you use.Find the line that says “post.Text (”\n M03\n")" and do it - post.Text (“\n M03 S1000\n”)
We believe we have your instructions and have updated this postprocessor as shown below. We still don’t turn the plasma on, unless we write S1000 after M03 in the post processed .tap file. Is there anything we can do to this postprocessor file to make it work?
USB-CNC plasma.scpost:
function OnAbout(event)
ctrl = event:GetTextCtrl()
ctrl:AppendText(“Milling/routing post for Eding CNC USB-CNC controllers\n”)
ctrl:AppendText(“\n”)
ctrl:AppendText(“Modal G-codes and coordinates\n”)
ctrl:AppendText(“Comments enclosed with ( and )\n”)
ctrl:AppendText(“Incremental IJ\n”)
ctrl:AppendText(“uses G43 tool length offsets\n”)
– revision 7/23/20
– Added S1000 to post.Text (“\n M03 \n”)
– revision 3/6/09
– Removed line numbers (they can conflict with 0-word subroutines)
– revision 3/2/07
– Removed final safety move. This is now done in SheetCam
– revision 7/10/04
– Added new arc handling
– Created 30/3/2005
– based on Mach2.post
function OnInit()
post.Text (" (Filename: “, fileName, “)\n”)
post.Text (” (Post processor: “, postName, “)\n”)
post.Text (” (Date: “, date, “)\n”)
if(scale == metric) then
post.Text (” G21 (Units: Metric)\n") --metric mode
else
post.Text (" G40 G90\n F1\n")
function OnNewLine()
post.Text (“N”)
post.Number (lineNumber, “0000”)
lineNumber = lineNumber + 10
function OnFinish()
post.Text (" M05 M30\n")
function OnRapid()
post.ModalText (" G00")
post.ModalNumber (" X", endX * scale, “0.0000”)
post.ModalNumber (" Y", endY * scale, “0.0000”)
post.ModalNumber (" Z", endZ * scale, “0.0000”)
post.Eol()
function OnMove()
post.ModalText (" G01")
post.ModalNumber (" F", feedRate * scale, “0.###”)
post.ModalNumber (" S", spindleSpeed, “0.##”)
post.Eol()
function OnArc()
if(arcAngle <0) then
post.ModalText (" G03")
else
post.ModalText (" G02")
post.NonModalNumber (" X", endX * scale, “0.0000”)
post.NonModalNumber (" Y", endY * scale, “0.0000”)
post.Text (" I")
post.Number ((arcCentreX - currentX) * scale, “0.0000”)
post.Text (" J")
post.Number ((arcCentreY - currentY) * scale, “0.0000”)
post.ModalNumber (" F", feedRate * scale, “0.0###”)
post.Eol()
function OnPenDown()
if (preheat > 0.001) then
post.ModalNumber (" Z", cutHeight * scale, “0.0000”)
post.Text (“\n G04 P”)
post.Number (preheat,“0.###”)
post.Eol()
post.ModalNumber (" Z", pierceHeight * scale, “0.0000”)
if (pierceDelay > 0.001) then
post.Text (" G04 P")
post.Number (pierceDelay,“0.###”)
post.Eol()
function OnPenUp()
post.Text (" M05\n")
if (endDelay > 0) then
post.Number (endDelay,“0.###”)
post.Eol()
function OnNewOperation()
post.Text (" (Operation: ", operationName, “)\n”)
function OnComment()
post.Text(" (“,commentText,”)\n")
function OnToolChange()
–[[post.Text (" M6 T")
post.Number (tool, “0”)
post.Text (" (“, toolName, “)\n”)
post.Text (” G43 H")
post.Eol()]]
function OnSpindleChanged()
if (spindleSpeed <= 0) then
post.Warning(“WARNING: Spindle speed is zero”)
function OnNewPart()
post.Text(" (Part: “,partName,”)\n");
function OnDrill()
OnRapid()
OnPenDown()
endZ = drillZ
OnMove()
OnPenUp()
endZ = safeZ
OnRapid()
