posting issue
Hello. I can import a part drawing and get the start points but when i click post it says it was completed but there is an error that states there was no feedrate? If i open the file in Mach it only has the header posted?
I had one completed part that ran on Mach correctly but i wanted to change just the feedrate. When i did, now it too only posts the header and i’ve lost the rest of the post? Am i forgetting something?
Thank you in advance.
Have you set up a cut? If you can’t see any green tool paths then either you haven’t set up a cut operation or it is trying to use the wrong layer. The tutorials in Help->tutorials may help.
