post processor not converting to tap file
post processor not working when trying to convert to tap file to load to mach 3, sheetcam3 is latest version 7.01.16 any ideas on how to fix problem or revert to previous version before update
Under Options-Machine-Post Processor, there is an a place called "Output File Extension. There you can type a file ext you want ie. .txt,.tap, ect.
So I would try looking their and see if that helps.
Are you using the correct post processor? The issue could also be your license. In SheetCam go to Help->about and PM your license ID.
