I have a Tormach 1300PL plasma and it uses Path Pilot software. I have recently been using Mach 4 post processor but a recent update and/or change in the software no longer lets Mach 4 work. It does not produce a cut G code. It will run through the operation as if it is in a Dry run, just doesn’t activate the plasma to turn on and off to start and stop cuts.
I have imported a PP from a previous post inside this forum group posted is 2022, https://forum.sheetcam.com/uploads/short-url/1AMRtZcgliofdmfNXRmozM4voHV.scpost , however it still does not operate correctly.
Is there a Post Processor that for Path Pilot that will work in sheetcam? Or do I need to stop using sheetcam and switch to a different software?
