I am setting up a DTHCIV on my old system… I can’t seem to find the correct Post Processor for it. On the master file, I only saw one 1V file, and that’s for the Hypertherm setup… Does not seems to work at all, Others run it, but it,like the MP300 DTHCII but not quite right as far as the THC goes.
I know it’s Toms Stuff, but kind of like to run it by you first. ( Lot less bite around here when asking dump questions) ![]()
Bit confusing on this point below… From the DTHIV manual…
Just got the table up, and running tonight, with the new system…
*This post is intended for use with the DTHCII and DTHCIV and a floating head setup.
There are MP3000 named posts and DTHC IV named POST. You should use the DTHCIV named posts
Scott
