New to running Sheetcam Mill/ Router. Programming an engraving operation using the contour method. Material is 1/4" thick aluminum.
Program settings are as follows…
Contour method: no offset
Layer: 1
Tool: T1 engraving tool
Start depth: 0 in
Cut depth: .03 in
Depth per pass: .03 in
Finish allowance: 0 in
Feed rate: 3.937 ipm
Plunge rate: 3.937 ipm
Ramp angle: 0 degrees
Error message reads: Post processing failed. You need to define the diameter.
Is this referring to tool diameter? I currently have the tip diameter set at .25.
