I’ve been working on setting up my plate marker for use and have noticed some issues. When I select my tool and it generates its path it all looks good. But when I go to run it, it leaves lines out, I have tried to leave things polylined, un-polylined, open with a small gap and nothing seems to make any difference. I even went thru and put all the starts in corners and it didn’t even start in the corner I told it to. I am running 6.0.15 so I believe I am up to date. Can anyone help with this?
Not sure where my other pics went. This one has so many things going on, it’s tough to see where its messed up at.
Can you see the missing tool paths in Mach?
Yes, tool paths look fine to me. Start points even seem to be different than what I set them to.
tool path pic if it loads for me…
We finally managed to sort this out. It was a bug in the post processor. The post used was CandCNCPlasma-rev11J.scpost from CandCNC. Switching to their CandCNCPlasma-rev11M3.scpost should fix the problem.
