Plasma Rotary drawing gussets to cut in 1 cut
I am trying to draw some gussets on some 1 1/2" square tube, and i cannot figure out how to draw them to get them to cut in one cut. if i draw them like shown in the pic, the simulation does some wierd shortcuts while cutting through the part to get were it needs to go. If i seperate it and put the extra top leg on its own on the bottom, then it cuts the single side separate from the main part. Am i missing something?
Brian
Do you have any overlapping or broken lines? If you send me the job file I’ll take a look and see if I can figure out what is going on.
tried it again in the development version and it worked great! Problem Solved!
