Plasma cut direction, how to set default?
Hi, how do I set the cut direction for a plasma tool? I can see how to reverse the direction after the tool is created and when it is being used in a toolpath, using the “reverse direction” option, but how is it set to start with. obviously on a mill toolpath its set by the spindle direction, but thats not an option for obvious reasons!
Just thought there must be a way to set all tools to default so that inside contours cut counterclockwise and external cut clockwise?
thanks
Nat
In a Jet Operation, using ‘Reverse direction’ will have OutsideOffset contour method cutting as you desire, it automatically alternates CW to CCW as it is applied to inner nested shapes.
yep, but I can’t see how to set reverse direction when creating the tool, I can only seem to select that after creating a toolpath with the tool?
