Path rules question
Hi Les, for flame cutting is there a way with the near pierce rule option to raise the Z and slow down the feed to work through a slag pile? I have tried adding a code snippet in the start code box but it puts the Z movement in before the programmed code Z move, in other words it shows in the code but the programmed depth is after it and it goes to that cut height, ignoring the higher setting.
I can get it to slow down the set distance from the pierce but not to raise up, is it possible?
I hope I haven’t made that too confusing!
Thanks again, Steve
.,._
Posted by: steve@adnaironworks.com
Visit Your Group
,.,_
Hi Steve
If the Z move is n a line by itself and does not incorporate the next X and Y moves, it will happen that the Z lifts first and then continue with the rest of the cut. What must happen is the trajectory of the move form where the snippet begins to where it ends must be a X, Y and Z move. Because plasma is in essence only a two axis movement, it might be a bit of a challenge and Les will have to advise.
Regards
Marius
http://www.cnccontrol.co.za
http://www.mastercut.co.za
On Saturday, November 1, 2014 6:47 AM, “steve@adnaironworks.com [sheetcam]” <sheetcam@yahoogroups.com> wrote:
Thanks again, Steve
.,._
Posted by: Marius Liebenberg <marius.liebenberg@yahoo.com>
Visit Your Group
,.,_
I hadn’t even thought about raising the Z. I’ll take a look and see what I can do.
On 01/11/14 04:47, steve@adnaironworks.com (steve@adnaironworks.com) [sheetcam] wrote:
Thanks again, S teve
.,._
Visit Your Group
,.,_
