In the program below, I have removed all Z moves, both rapid and feed rate. If you look at line 90 there is a G00. This is where a Z rapid would normally be but since I removed that line in the post, the Z move does not appear. Is there a way to make the entire line go away?
N0000 (Filename: oxy test.tap)
N0010 (Post processor: TruCutCNC - OxyFuel.scpost)
N0020 (Date: 17/09/2011)
N0030 G20 (Units: Inches)
N0040 G53 G90 G40 G91.1 M7 M1100
N0050 F1
N0060 (Part: GANTRY INNER BEARING SUPPORT)
N0070 (Process: Outside Offset, OUTSIDE, T113: Oxy/Fuel)
N0080 M06 T113 (Oxy/Fuel)
N0090 G00
N0100 G00 X-0.2661 Y2.7601
N0110 G04 P5
N0120 M1102
N0130 G03 X0.0603 Y2.9168 I0.0849 J0.2415 F12.0
N0140 G01 X0.8683 Y5.2152 F12
N0150 G02 X1.1998 Y5.5416 I0.4966 J-0.1729 F12.0
N0160 G01 X2.4468 Y5.9495 F12
N0170 G02 X3.5214 Y5.9495 I0.5373 J-1.6410 F12.0
N0180 G01 X4.7685 Y5.5416 F12
N0190 G02 X5.1000 Y5.2152 I-0.1650 J-0.4992 F12.0
N0200 G01 X5.8772 Y3.0043 F12
N0210 G02 X5.9362 Y2.6580 I-0.9853 J-0.3462 F12.0
N0220 G01 Y0.2814 F12
N0230 G02 X5.6604 Y0.0013 I-0.2781 J-0.0021 F12.0
N0240 G01 X0.2771 F12
N0250 G02 X0.0013 Y0.2814 I0.0022 J0.2781 F12.0
N0260 G01 Y2.5705 F12
N0270 G02 X0.0603 Y2.9168 I1.0444 J0.0001 F12.0
N0280 G03 X-0.0963 Y3.2432 I-0.2415 J0.0849
N0290 M1103
N0300 G00
N0310 G00 X0 Y0
N0320 M05 M30
OK…Made it go away by setting rapid clearance to 0, but I’d rather make a change to the post so rapid clearance can be left alone. Setting it back for a plasma part after changing it to 0 for a flame cut part is just one more thing to forget.
That line is harmless but if you want to get rid of it, put this line right at the beginning of your OnRapid()
if(math.hypot(currentX - endX, currentY - endY) < 0.001) then return end
