I can not specify the diameter of a v-cutter. Now I am wondering what is the distance of the offset if I use this tool on an outside/inside offset contour operation…
…or should I use the tip diameter as the tool diameter? I am using the following tool for deburring and chamfering: http://tinyurl.com/loll7yd
C.
