I’m trying to use sheetcam to create g-code for my plasma cutter which uses Mach 3 to operate. When I generate g-code and open this .tap fail what was created then there is just a drawing file name and cutting parameters. Drawing have not been translated. On sheetcam all is ok and cutting path is correct. Is there something I have missed?
Yes, I have created cut operation but simulation does not work either. Post protcessor displays messaga that feed rate is zero. But my feed rate is set under jet cutting tool. Can I define it elswere?
If simulation doesn’t work then there are no cut paths. Do you have the correct layer selected in each cut operation? Can you post a copy of the job file (file->save job) here or send it to me in an email so I can take a look at it.
Well, that’s strange. It works perfectly for me. It simulates and generates code correctly. Have you got a license installed? I have seen similar problems before when someone had a corrupted license file.
If you look in Help->about, does it say if SheetCam is registered?
Yes, it’s registred to some lou. I tried to make fresh install but somehow it find my old machine configuration and the same lou. How can I cange it into demo or non registred version?
