New user; feedRate is zero
Warning: WARNING: Feed rate is zero
Post processing completed with 1 warnings
Hi, I had to use my son’s Dell computer because mine fried. Sheet sent me my license to my son’s computer. now I post processor then when I try to cut and this fun little message appears Warning: WARNING: Feed rate is zero
Post processing completed with 1 warnings. I have plasma torch set at 10 ipm with .25 plate. Please help let me know in layman, simple terms I’m not the sharpest tool pun intented in the shed.
This error can be caused by a number of conditions:
  • the cutting feed rate and/or the plunge feed rate in the tool definition is zero. the fix, give both of them a non zero value
  • your license has been pirated and rendered useless.
  • you haven’t defined a Jet Operation.
there may be other causes related to user error.
To be certain about the cause, please send us a customer support zip file per these instructions: Creating a Sheetcam Customer Support file
In the meantime of us reviewing your file, consider reviewing some of these new user tips: Where to learn Sheetcam - #2 by sheetcamCS2
