Hello all,
I have been using Sheetcam for a number of years with CommandCNC for Plasma with great success. Recently I added a water cooled 2.2 KW spindle and Huanyang VFD to the mix. I purchased and hooked up the new ISS-05 spindle control from CommandCNC for RS-485 control to the VFD and it works great. I have added a tool setter, and per their instructions have basic tool change and tool setter locations keyed in and all works as designed.
Never having used Sheetcam for routing, I need a little help in understanding the options/process for making parts and having the spindle know where to go after the tool change and tool setter functions. I am told that the process is manual for now and eventually there will be a post for semi auto tool changes. I understand the process of the tool change itself and the tool length offset via the tool setter, but I am totally confused with locating the part on the table and having the gcode tell the spindle where to go after each tool change since the table has to be homed and zeroed (X,Y) prior to using the tool change and tool setter functions.
In Plasma, I move the torch to a place on the metal that accommodates the part, zero all axes and hit run. How can I tell the spindle where to go and get repeatability with the different features and tools? If I understand correctly, I need separate files for each feature to be cut separately, in lieu of combining all of the features into one file/gcode that has embedded tool change pauses. I have attached a file of a speaker trim ring as an example. Any direction here is greatly appreciated.
Thank you,
68 Camaro Speaker Trim Ring 2022 0603.job (57.4 KB)
