Hi Guys this may have been covered before but I can’t find it in the search engine. I was wondering if I toolpath individual items can I then bring them together already tool pathed. I do a lot of repeditive parts but not enough to fill one sheet each time so I was hoping to be able to use a previous tool pathed item to save having to re path each time I use it in a different nest.
You can save tool pathed parts in File->save part. You can then load that part at a later date. Note parts don’t contain the tool settings so if you change your tool set your operations will be affected.
Sounds great will give it a go.
