HI i have a Extron MIRL CONTROL Mill I’m trying to control with Sheetcam, I’ve been using it for years with mach3 no issues and only just started with this new macine.
although with this machine i get INT 132 faults (illegal Radius) fault
Code descriptioon
(1) End point on G02, G03 for arc cutting is not on the arc
(2)Check the vectors of center and endpoint
(3) Press Reset to Clear the error.
Ive tried making adjustments and still get this fault every now and then.
Any advice would help, the Post processor I"ve been working on making it work so there may be issues with it.
function OnAbout(event)
ctrl = event:GetTextCtrl()
ctrl:AppendText(“EXTRON E216 MIRL M2000 POST PROCESSOR\n”)
ctrl:AppendText(“Non modal G-codes\n”)
ctrl:AppendText(“Modal coordinates\n”)
ctrl:AppendText(“All Comments preceeded by semicolon\n”)
ctrl:AppendText(“Incremental IJ\n”)
ctrl:AppendText(“uses G43 tool length offsets and H values from machine tool table\n”)
– revision 3/2/07
– Removed final safety move. This is now done in SheetCam
– revision 25/5/06
– Revised rigid tapping spindle on/off sequencing
– revision 11/5/06
– revision 4/5/06
– Revised tapping cycles
– revision 2/5/06
– Added tapping cycle
– revision 14/11/05
– Fixed circles for Mach2/earlier versions of Mach3
– revision 20/10/04
– added tool length offsets
– revision 25/10/04
– added G90.1 incremental IJ mode
– revision 28/7/04
– Added drill start depth
– revision 19/7/04
– added drill cycle
– revision 28/6/04
– Replaced startx,y,z with currentx,y,z
– Revision 28/5/04
– Unbodged first rapid move - main app is fixed now
– Added plunge,feed,spindle speed warnings
– Revision 25/5/04
– fixed feed rate problem and bodged first rapid move
– Revision 18/5/04
– Added Metric + Inch variables and easy inch/metric swapping
– changed to fixed number of trailing zeros
– Created 11/5/2004
function OnInit()
post.TextDirect(“%\n”)
post.SetCommentChars (“()abcdefghijklmnopqrstuvwxyz”, “ABCDEFGHIJKLMNOPQRSTUVWXYZ”) --make sure ( and ) characters do not appear in system text
post.Text(" /*DATE: “,date,” TIME:“,time,” */ \n")
post.Text (" /*POST PROCESSOR: EXTRON E216 SHEETCAM */ \n")
if(scale == metric) then
post.Text (" G21 /*UNITS METRIC */ \n") --metric mode
else
post.Text (" G20 /*UNITS INCHES */ \n") --inch mode
post.Text (" G17")
post.Eol ()
post.Text (" G94")
post.Eol ()
post.Text (" G90")
post.Eol ()
post.Text (" G49")
post.Eol ()
post.Text (" G54")
post.Eol ()
post.Text (" M45")
post.Eol ()
function OnFinish()
post.Text (" M30\n")
function OnRapid()
post.ModalText (" G00")
post.ModalNumber (" X", endX * scale, “0.00”)
post.ModalNumber (" Y", endY * scale, “0.00”)
post.ModalNumber (" Z", (endZ + toolOffset) * scale, “0.00”)
post.Eol()
function OnMove()
post.ModalText (" G01")
post.ModalNumber (" F", feedRate * scale, “0.0###”)
post.Eol()
function OnArc()
if(arcAngle <0) then
post.ModalText (" G03")
else
post.ModalText (" G02")
post.NonModalNumber (" X", endX * scale, “0.0###”)
post.NonModalNumber (" Y", endY * scale, “0.0###”)
post.ModalNumber (" Z", (endZ + toolOffset) * scale, “0.0###”)
post.Text (" I")
post.Number ((arcCentreX - currentX) * scale, “0.0###”)
post.Text (" J")
post.Number ((arcCentreY - currentY) * scale, “0.0###”)
post.Eol()
function OnSpindleCW()
post.ModalNumber (" S", spindleSpeed, “0.##”)
post.Text (" M03")
post.Eol()
function OnSpindleCCW()
post.Text (" M04")
post.Eol()
function OnSpindleOff()
post.Text (" M05\n")
function OnNewOperation()
post.Text (" /*OPERATION “, operationName, " */ \n”)
function OnComment()
post.Text(" /*“,commentText,” */ \n")
function OnToolChange()
post.Text (" /*“, toolName, " */ \n”)
post.Text (" M06")
post.Text (" T")
post.Number (tool, “0”)
post.Eol()
post.Text (" G43 H")
post.Eol()
if (plungeRate <= 0) then
post.Warning(“WARNING: PLUNGE RATE IS ZERO”)
if (feedRate <= 0) then
post.Warning(“WARNING: FEED RATE IS ZERO”)
function OnNewPart()
post.Text(" /*PART: “,partName,” */ \n");
function OnFloodOn()
post.Text(" M08 /*FLOOD COOLANT ON */ \n")
function OnMistOn()
post.Text(" M07 /*MIST COOLANT ON */ \n")
function OnCoolantOff()
post.Text(" M09 /*COOLANT OFF */ \n")
function OnDrill()
post.ModalText (" G83")
OnRapid()
depth = drillStart
buffer = plungeSafety
endZ = depth + buffer
OnRapid()
if(drillRetract < buffer) then
buffer = drillRetract
while depth > drillZ do
OnRapid()
depth = depth - drillPeck
if (depth < drillZ) then
depth = drillZ
endZ = depth
OnMove()
if (depth > drillZ) then --retract if we need to take another bite
endZ = endZ + drillRetract
if (endZ > safeZ) then
endZ = safeZ
OnRapid()
if (endZ < safeZ) then
endZ = safeZ
OnRapid()
function OnSetFeed()
function OnTapStart()
post.Text(" M49\n") --disable FRO
post.Text(" G95\n") --feed per rev
function OnAutoTap()
clearance = 1 --tapping clearance height
–move to hole X,Y coordinates
OnRapid()
–move to tapping clearance height
clearance = clearance + drillStart
endZ = clearance
OnRapid()
–feed to depth
feedRate = tapPitch * underFeed
OnSetFeed()
endZ = drillZ
OnMove()
–retract to engage reverse clutch
endZ = drillZ + tapTravel
feedRate = 10000
OnMove()
–feed out
feedRate = tapPitch * reverseMult * underFeed
endZ = tapTravel + clearance
OnMove()
–retract to clearance plane
endZ = safeZ
OnRapid()
function OnRigidTap()
–spindle forwards
if (spindleDir == 1) then
OnSpindleCW()
else
OnSpindleCCW()
spindlecache = spindleSpeed
OnRapid()
endZ = clearance + drillStart
OnRapid()
–tap to depth, correcting for underfeed
OnSetFeed()
depthfix = (drillStart - drillZ) * (1 - underFeed)
endZ = drillZ + depthfix
OnMove()
–reverse spindle
OnSpindleOff()
spindleSpeed = spindlecache * reverseMult
if(spindleDir == -1) then
OnSpindleCW()
else
OnSpindleCCW()
–feed out
OnSetFeed()
OnMove()
–stop spindle and restore speed to tapping speed
OnSpindleOff()
endZ = safeZ
OnRapid() --retract to clearance plane
function OnTapEnd()
post.Text(" M48\n") --enable FRO
post.Text(" G94\n") --feed per min
