MASSO Plasma DTHC w Rotary
With advice from a MASSO controller user, I’ve attempted to add rotary support to the std MASSO Plasma DTHC scpost.
attached are a job file so you can see my test case, the gcode, and the .scpost.
It looks correct, but since I don’t have a MASSO controller I’ve not run it.
Use a pipe wall thickness of 0mm when you do rotary setup, and set the pipe diameter to the outside diameter dimension.
Apparently SC sets the zero degree point on the cylinder at the midpoint of the flattened shape in the sketch window.
Zero Z to the cylinder wall, as you would expect.
Let me know how it goes.
sc rotary test.nc.txt (1.44 KB)
MASSO Plasma DTHC w Rotary LDC.scpost (7.44 KB)
sc rotary test.job (14.5 KB)
