Les…I’ve seen mention of a rotary post, but it’s not in the posts directory. Is it still viable? Could you send it to me?..Or post it here? Thanks
That post wil lbe in the next dev release. I have attached a copy of the post here. Note that it only works for plasma cutting and is designed to run with THC. You need to edit the post. At the beginning are a bunch of settings you need to tweak for your machine.
Too use the post you must define a variable called ‘diameter’ that contains the diameter of the tube (use the V button). This must appear at the top of the operations list, before any cuts.
