Thanks for fixing the mach3 plugin, it now recognizes my mach.
But, i must be missing a step, cause when i post process, it doesnt load in mach…dont flame me please…
the plugin is enabled
And what is the new button M that"notifies mach when post process is complete" ?
if i open it, all the fields are gray, i cant do nothing.
Must be something simple im missing, i just dont know what.
When you go to Options->plugin options->mach does it say a compatible version of Mach3 was detected?
In the plugins menu is ‘Enable Mach3’ turned on? Do you see the Mach3 plugin in SheetCam. It should have X,Y,Z DROs and a number of other buttons. Are the buttons greyed out even if Mach is running?
Run Mach and go to Config->Config plugins and make sure the ‘SheetCamRemote’ plugin is enabled.
DUH!! It wasnt enabled in mach…i knew it was simple!
Just need to add arc volts to toolsets with DCC, and voilà!
Post, and everything is ready in mach ![]()
