linux
hi,just want to know sheetcam can install on linuxcnc?thanks.
Yes, there is a Linux version which should be able to install on a standard LinuxCNC installation. You can download it from the SheetCam website.
ok,thanks Les.
Hi, Les!
Can I use the Rotary pipe cutting plugin for SheetCamTNG Linux? How to buy this plugin for SheetCamTNG Linux , or for Linux plugins is free? If that plugin for Linux exists, where can I download it?
Many thanks
Yup, it’s available in both versions. It is an extra cost option so you need to purchase a license through the website. I sent you a 30 day license in reply to your PM.
Many thanks, Les!
Hi Les
Many moons ago I purchased a code for “Rotary pipe cutting” using in Mach 3
I have now upgraded my system and I am running Candcnc command software for LINUX
I am just in the process of updating my version of sheetcam TNG to 6.1.57 as ell as the latest version of command software
Will my original code/license still work under the above set up?
Best regards as always and thanks for such a great product
Yes it will work. Rotary keys are linked to your SheetCam license so you must use both.
