If you always use the same layers then load a drawing that has all 3
layers. Set up a cut on layer 0 with no offset. Now set up a cut on
layer 1 with inside offset and so on. You will now have three cut
operations listed on the left hand side. Save the job. Now when you
need to set up a new drawing, load the job and import your drawing into
it. The new drawing will replace the old drawing. If any layers are
missing, that cut will give a warning but you can ignore it.
So, is it possible to set a different lead-out for a hole in plasma cutting, than the lead-in?
See, once the part is cut, it falls off, and leaves a big nothing, which leads to an error on my machine.
Excellent post. I want to thank you for this informative read, I really appreciate sharing this great post. Keep up your work. Thanks for this very useful
