I’m on an Eastwood Versacut 60 cnc table, On a learning curve for sure but as I was making progress, I seem to have developed a systemic problem with the post processor. I have successfully run plenty of files posted out of sheetcam but now, some are being rejected by my eastwood controller reporting “kerf error” with a line number.
When I look at the line in notepad it is usually just another x/y coordinate.
In my next post is an update now that I have a slightly better understanding of what is happening, but it is still a problem.
After some fiddling it seems to have to do with offsets. If I remove offsets, the file loads and cuts, but does not do lead ins or seem to follow path rules. Now I’m wondering what the disconnect is between sheetcam, the Eastwood post processor and my brain. It’s is clear which is the weakest link.
One constant in my early experience is that it appears my cnc controller is not fully picking u instructions I thought were defined in the sheetcam job file and g-code file. Lead ins are not happening correctly or at all, path rules are not happening and I am having to manually enter some settings that I have also set in the tool and operation settings.
If so, that table uses a Chinese controller with very finicky controller settings. Also, as I recall, the controller ignores Z motion in the gcode file. Z is controlled by a DC motor (not a stepper) and it is entirely dependent on the THC circuit for height control while the torch is ON. With the torch OFF, Z height is determined by timing units (seconds defined to +/- 0.1 secs)… recall I said it was a DC motor, not a stepper. The good news is, none of that seems to be directly related to the ‘kerf error’ you are reporting, but how Z is managed is good to know eventually as you learn to operate this table.
I’m also recalling that those style Chinese controllers can and usually use kerf offset gcode (G41, G42). That may be why using sheetcam ‘No Offset’ jet operation is not throwing controller ‘kerf error’. Leadin/out and path rules problems can easily be related to use of G41/42.
What you can do:
1.) upload the gcode file from a very simple job that fails with the ‘kerf error’ controller problem. Also upload the sheetcam .job file, and the post processor file that you are using.
I and others will look at those files and perhaps be able to help.
contact Eastwood support. Their controller is very finicky. Odds are there is some obscure controller setting that got changed. Only an expert for that controller will be able to advise in that case.
Sheetcam’s “Error: Evaluation limit reached” is hard to miss during post processor runtime, red text in a forced message box popup. OP does not mention this condition.
Thank you for the reply. I truly appreciate it. I seem to be past that particular error for the moment but it could easily pop up again soon. My urgency was mostly related to having gotten half way through a sheet with nested cuts not yet complete and I wanted to try to salvage the rst of the cuts before moving the sheet.
I will upload the next file that does this. For the moment I got past it, but plan to do a lot of cutting with a variety of designs in the next few weeks.
