Hi,
Im pretty new to this. Im running a CNC plasma at work, our machine is new and none of us are very familiar with the software. Im the only one that’s able to really run the machine only because im familiar with computers. We’re running sheetcam and mach3. The part im cutting is a silhouette of a model a Ford for a customer. The outside cut is pretty straight forward, only probes once for the torch height. The inside cuts there’s something like 15 cuts and the torch probes for everyone of them. This is adding on way to much time per piece, and on top of that the torch ends up probing to far in some times. When this happens I have to reset mach3, lift the head, rest z height, find a good rest point in the g code and start it up again. This is also eating up time. Now here is the question. Is there any way to setup for the torch to probe only once for the inside cuts? The cuts are small and won’t warp the piece, so there’s absolutely no need to probe every cut.
Thanks for any help.
