I am looking for a way to automatically reverse the start order of cuts without having to manually use Quick Cut Sequence.
If not in Sheetcam, is there a way to use post processing to reverse the order?
I ask, because I have several hundred cut files that I also need to have upside down versions of, and my plasma cutter requires that I cut from bottom to top. I can rotate the part 180 degrees, but I would like to not have to resequence all of the cuts
