Importing DFX and manipulateing
I got An DFX file when i import the part is not on the work space it is up and to the left.and a square closer to work space I attched it take off the .zip might work
regplatetype1d.dxf.zip (15.0 KB)
You control the placement of the dxf drawn part on the sheeetcam Import dialogue. If that is not sufficient, you can move the part XY and rotate the angle after import using Tools-Nesting, drag and drop the part or use the XYA input fields in the bottom right corner of the main sheetcam toolpath screen.
Also, you control the XY Origin (00) location on the toolpath screen via the Options-Job Options-Material window.
Thanks Got something to work.
But I Get layer does not exist ?
