Hello
What is the best DXF export scheme from rhinoceros to sheetcam where we can obtain more accurate drawing & reducing the segment inside the drawing
I don’t use Rhino but my general advice for CAD is to use the earliest dxf version they offer.
I would also like to add, if you are referring to the segments after the dxf is imported into sheetcam, take a look at the settings in Options>Application Options>Drawing Import. These settings make a huge difference on how the dxf is imported. Play around with these some until you find what is comfortable for you. I find that for 99% of my drawings the settings in this screenshot seems to work pretty well.
