How to edit toolbar on left side?
How do I edit the the Operations buttons on the left side? I’d like to remove certain ones I don’t use.
I don’t think you can directly edit that toolbar. You can change the machine type to remove the mill rotary buttons.
Yes, that’s right. Go to Options->machine and make sure only the machine types you want are selected.
Ok thanks
If you go to Options/Application Options/Tool bars, it will give the option to edit or create new tool bars. Be careful though, it can be a little tricky.
I don’t think that works on the operation buttons.
