How to center mark small holes with scribe only?
For some time now we are successfully using “plasma drill” operation to pierce centers of small holes for manual drilling later.
I export DXF from SolidWorks, all small holes go to separate layer in Sheetcam, then set hole min-max, plasma drill and tadaa - works perfect!
However when it comes to manual drilling these pierced holes after - everyone knows what happens to drill bits if you got plenty of holes to drill… :frowning:
For now, when it comes to marking numerous small holes we stopped using plasma drill pierce operation and instead we use only plate marker.
Instead of holes - I simply sketch in Solidworks hole center marks (2x 5mm line cross), then export to DXF and in Sheetcam set scriber operation for all
center marks - crosses. This works great - however very time consuming to draw additional center marks in Solidworks.
What would be the easiest way to accomplish this? Maybe new feature?
No more plasma pierce or peck-pierce holes - simply every single hole (f.e. up to 10mm diameter) must have 5x5mm cross mark done by plate marker.
We are using plate marking operation extensively for most bend lines from Solidworks, positioning marks for welding and lately almost for
all small holes, all for prototyping before it goes to laser and CNC press.
I noticed new “Shape library feature” so simple cross to use as center mark for holes will do, but then also very time consuming to place these all
over the material - not mentioning how to position-snap them into circles (holes).
Thank you very much in advance for any elegant solution or advice.
Miro.
Hi Miro,
I dunno I would rather sharpen the odd drill bit than start from scratch centre punching and working up to a 10mm hole, I normally plasma 1mm under finished size and open up with drill for more precise jobs, right speed a decent bit and some cutting lube and it’s not much bother really.
Sean
Hi Sean,
Thanks for your input, could you be please more specific?
Part example:
steel plate: 6mm
hole diameter: 6mm
number of holes: 30
average distance between holes: 50mm - tolerance 0.5mm :open_mouth:
So you would plasma pierce through, then what drill size? What kind/type?
Or burn 4-5mm holes then open up? :laughing:
What about damaged torch tips after piercing multiple parts?
Decent prepared smaller holes for bolts or for tapping after plasma has been nothing but torture for me so far,
so I am under impression that there is no point of plasma piercing for holes under 5-6mm…
Umm maybe pushing it a bit there with burning a 5mm hole in in 6mm sheet, I quite often cut a 9mm dia in 8mm thick and open up to 10mm though,
just using dormer hss bits, maybe that’s how I get though a few consumables :laughing:
Try plasmatech.co.uk , not genuine hypertherm but seem to last just as well, good bit cheaper.
You can add the Gcode to do a simple X mark at the drill point center from the post.
From the drill center point
Mxxx (turn on scribe)
G91 (set Inc mode)
G1 X-.500 (move to startpoint)
G1 X1.00
G1 X-.500
G1 Y.500
G1 Y-1.00
G1 Y.500
Mxxx (turn off scribe)
G90 (reset mode to ABS)
Now everytime you call for a center drill operation it will post that code to do a X marking.
(:wink: TP
YES! :astonished:
That’s exactly how I want it, thank you Vmax.
I actually never edit anything under settings section in my post, but I am eager to learn…
Where do I put it?
function OnDrill() ???
Below is my post, could you please kindly help me to fix it?
Thank you very very much.
Miro.
--*** Set these values up to suit your machine ***
--this is the distance between each torch reference in MILLIMETRES
refDistance = 250
--this is the reference feed rate in mm/min
refFeed = 1000
--Put your switch offset value here in MILLIMETRES
switchOffset = 0
--Scriber X,Y,Z offsets in MILLIMETRES. Do not use inches here even if you want inch code
--For the marker use the scriber Z as the offset from Z zero you want the Z to move to during a scribe.
--Change these values to suit your scriber setup
scriberX = -88.1
scriberY = 32.8
scriberZ = 14
--scriber axis. Leave this as nil if the scriber is fixed to the same axis as the torch
--scriberAxis = "A"
scriberAxis = nil
--If this value is set to true then use G28 (home) for the Z reference
--Set it to false for G31 probe
refHome = true
--this value when set to "true" will set the Z to lift to rapid height between paths when using the marker tool.
--if false it will not lift the Z between paths but will at the end
markerZ = false
--The cutter will slow down for corners and turn off THC below this radius
--Set slowRadius to "0" to turn off the auto slowdown
slowRadius = 0
--Minimum slow down speed.
--This is a scale factor. For instance 0.5 = 50% of the current feed rate
slowPercent = 0.6
--THC on and off codes. Use nil if you don't want THC control e.g:
-- thcOnCode = nil
-- thcOffCode = nil
--these codes are for the DCC extensions and turn the DTHC on/off if you have DTHC REV1/4 or higher firmware
thcOnCode = " S20"
thcOffCode = " S10"
--***           End of settings                ***
function OnAbout(event)
   ctrl = event:GetTextCtrl()
   ctrl:AppendText("Plasma MP3000-DTHCII post processor with/without Plate marker\n")
   ctrl:AppendText("This POST for all units without RS485 needing DCC ")
   ctrl:AppendText("\n")
   ctrl:AppendText("M03/M05 turn the torch on/off\n")
   ctrl:AppendText("M08/M09 turn the engraver on/off\n")
   ctrl:AppendText("Incremental IJ - set in mach2\n")
   ctrl:AppendText("The torch is referenced at cut start and every XXmm of movement thereafter\n")
   ctrl:AppendText("Designed for use with Mach3 and CandCNC MP3000-DTHC and Floating head Touch-n-Go\n")
   ctrl:AppendText("Post variables:\n")
   ctrl:AppendText("refDistance - set the distance between each reference\n")
   ctrl:AppendText("refFeed - set the feed rate when referencing\n")
   ctrl:AppendText("switchOffset - set your net switch offset amount \n")
   ctrl:AppendText("Scriber uses any tool number\n")
   ctrl:AppendText("slowRadius - slow down below this radius\n")
   ctrl:AppendText("slowPercent - minimum percentage to slow down\n")
   ctrl:AppendText("markerZ- allows marker rapid travel at system rapid height or Z offset height\n")
--  Modified 21/6/2010
--  added option for 'nil' plate marker z
--  Added support for plate marker tool type as well as tool number based plate marker
-- Modified 4/11/2010
-- Added: Reference the torch on the first pen down if the plate marker is the first tool used.
--Modified 22/4/2013 (TLC)
--Added Preset Volts , Preset Amps , and DTHC Delay variables
--Added markerZ to turn safe Z lift on marker tool on/off
--Changed scriberZ as Z axis offset from Z0
--Added code to turn off slowdown if slowRadius = 0
--Added  NODTHC, Tip SIze and Air Pressure to tool table variables
--Removed using tool number above 100 as marker tool--must use "Marker Tool" to select scriber
post.DefineVariable("refDistance",sc.unitLINEAR,0,1e17)
post.DefineVariable("refFeed",sc.unitFEED,0,1e17)
post.DefineVariable("switchOffset",sc.unitLINEAR,-1e17,1e17)
post.DefineVariable("slowRadius",sc.unitLINEAR,-1e17,1e17)
post.DefineVariable("slowPercent",sc.unitPERCENT,-1e17,1e17)
post.DefineCustomToolParam("PlasmaTool", "Preset volts", "presetVolts", sc.unit0DECPLACE, 49, 0, 200)
post.DefineCustomToolParam("PlasmaTool", "DTHC delay -sec", "dthcDelay", sc.unit1DECPLACE, 0, 0, 99)
post.DefineCustomToolParam("PlasmaTool", "Tip Size -Amps", "tipSize", sc.unit0DECPLACE, 40, 20, 200)
post.DefineCustomToolParam("PlasmaTool", "NO DTHC - 0", "dthcOff", sc.unit0DECPLACE, 1, 0, 1)
function OnInit()
   offX = 0
   offY = 0
   offZ = 0
   post.SetCommentChars ("()", "[]")  --make sure ( and ) characters do not appear in system text
   if(scale == metric) then
   else
   post.Text (" F1\n G53 G90 G40\n")
   if(dthcOff) then
--don't do anything
   else
     dthcOff = 1 --don't pass a null
   minArcSize = 0.2 --arcs smaller than this are converted to moves
   firstRef = true
   currentZAxis = "Z"
   finalCut = false
   dist = 9999999
   lastz = 0
   thcstate = 1
   ThcOff()
function OnNewLine()
   post.Text ("N")
   lineNumber = lineNumber + 10
function OnFinish()
   finalCut = true
   endZ = safeZ
   OnRapid()
   endX = 0
   endY = 0
   offX = 0
   offY = 0
   offZ = 0
   OnRapid()
   post.Text(" S900 \n")
   post.Text(" M22 \n")
   post.Text(thcOffCode)
   post.Text(" (DTHC is off)\n");
   post.Text (" M05 M30\n")
function OnRapid()
   if&#40;endX < 1e17 and endY < 1e17&#41; then --don't update the distance moved if X or Y are unknown
      local len = math.hypot&#40;&#40;endX + offX&#41;-currentX , &#40;endY + offY&#41;-currentY&#41;
      dist = dist + len
   post.ModalText &#40;" G00"&#41;
   post.ModalNumber &#40;" X", &#40;endX + offX&#41; * scale, "0.0000"&#41;
   post.ModalNumber &#40;" Y", &#40;endY + offY&#41; * scale, "0.0000"&#41;
   if&#40;toolClass == "MarkerTool"&#41;  then
      if&#40;firstRef == true&#41; or &#40;finalCut == true&#41; or &#40;markerZ == true&#41; then
         post.ModalNumber &#40;" Z", safeZ * scale, "0.0000"&#41;
      finalCut = false
   else --this is not a marker tool
      post.ModalNumber &#40;" Z", endZ * scale, "0.0000"&#41;
   post.Eol&#40;&#41;
function OnMove&#40;&#41;
   local len = math.hypot&#40;endX - currentX , endY - currentY&#41;
   dist = dist + len
   if&#40;len > slowRadius&#41; and &#40;dthcOff > 0&#41; then
     ThcOn&#40;&#41;
   post.ModalText &#40;" G01"&#41;
   if&#40;toolClass ~= "MarkerTool"&#41; then
   post.ModalNumber &#40;" F", feedRate * scale, "0.0###"&#41;
   post.Eol&#40;&#41;
function OnArc&#40;&#41;
   local radius = math.hypot&#40;currentX - arcCentreX, currentY - arcCentreY&#41;
   dist = dist + radius * math.abs&#40;arcAngle&#41;
   if&#40;radius < slowRadius&#41; and &#40;math.abs&#40;arcAngle&#41; > 0.5&#41; then
      feed = &#40;radius / slowRadius&#41;
      if&#40;feed < slowPercent&#41; then
         feed = slowPercent
      feed = feed * feedRate
      ThcOff&#40;&#41;
   else
      feed = feedRate
	 if&#40;dthcOff >0&#41; then
      ThcOn&#40;&#41;
   if&#40;arcAngle <0&#41; then
      post.ModalText &#40;" G03"&#41;
   else
      post.ModalText &#40;" G02"&#41;
   post.Text &#40;" I"&#41;
   post.Number &#40;&#40;arcCentreX - currentX&#41; * scale, "0.0000"&#41;
   post.Text &#40;" J"&#41;
   post.Number &#40;&#40;arcCentreY - currentY&#41; * scale, "0.0000"&#41;
   post.ModalNumber &#40;" F", feed * scale, "0.0###"&#41;
   post.Eol&#40;&#41;
function ThcOff&#40;&#41;
   if&#40;not thcOffCode&#41; then return end
   if&#40;thcstate ==1&#41; then
      thcstate = 0
      post.Text&#40;thcOffCode&#41;
      post.Text&#40;" &#40;DTHC is off&#41;\n"&#41;;
function ThcOn&#40;&#41;
   if&#40;not thcOnCode&#41; then return end
   if&#40;toolClass == "MarkerTool"&#41;  then return end
   if&#40;thcstate ==0&#41; then
      thcstate = 1
      post.Text&#40;thcOnCode&#41;
      post.Text&#40;" &#40;DTHC is on&#41;\n"&#41;;
      return
   if&#40;thcstate == 2&#41; then
      thcstate = 0
function OnPenDown&#40;&#41;
      if &#40;firstRef&#41; then
         Reference&#40;&#41;
         offX = scriberX
         offY = scriberY
         offZ = scriberZ
         if &#40;offZ > 0 &#41; then --put in the Z offset height if it the first scribe after a ref
            post.NonModalNumber&#40;" Z", offZ * scale, "0.0000"&#41;
            post.Eol&#40;&#41;
         post.ModalNumber &#40;" X", &#40;currentX + offX&#41; * scale, "0.0000"&#41;
         post.ModalNumber &#40;" Y", &#40;currentY + offY&#41; * scale, "0.0000"&#41;
         post.Eol&#40;&#41;
      else --not a ref move
         if &#40;markerZ == true &#41; then --put in the Z offset height before the scribe after the rapid
            post.ModalNumber&#40;" Z", offZ * scale, "0.0000"&#41;
            post.Eol&#40;&#41;
      post.Text&#40;" M08\n"&#41;
   else --tool is not marker tool
      if&#40;dist >= refDistance&#41; then
         dist = 0
         Reference&#40;&#41;;
      post.NonModalNumber&#40;" Z", pierceHeight  * scale, "0.0000"&#41;
      post.Eol&#40;&#41;
      if &#40;preheat > 0&#41; then
         post.Text &#40;"\n G04 P"&#41;
         post.Number &#40;preheat,"0.###"&#41;
         post.Eol&#40;&#41;
      post.Text &#40;"\n M03\n"&#41;
   if &#40;pierceDelay > 0&#41; then
      post.Text &#40;" G04 P"&#41;
      post.Number &#40;pierceDelay,"0.###"&#41;
      post.Eol&#40;&#41;
  thcstate = 0
 if&#40;dthcOff > 0&#41; then
  ThcOn&#40;&#41;
  post.Text &#40;" M22 \n"&#41;
function Reference&#40;&#41;
   firstRef = false
   if &#40;refHome&#41; then
      post.ModalText&#40;" G28.1 Z"&#41;
      post.Number&#40;3 * scale, "0.00"&#41;
   else
      post.ModalText&#40;" G31 Z -100"&#41;
   post.ModalNumber &#40;" F", refFeed * scale, "0.0###"&#41;
   post.Eol&#40;&#41;
   post.ModalText&#40;" G92 Z0.0\n"&#41;
   post.Text&#40;" Z"&#41;
   post.Number &#40;switchOffset * scale, "0.0000"&#41;
   post.Eol&#40;&#41;
function OnPenUp&#40;&#41;
      post.Text&#40;" M09\n"&#41;
   else
      post.Text &#40;" M05\n"&#41;
   if &#40;endDelay > 0&#41; then
      post.Number &#40;endDelay,"0.###"&#41;
      post.Eol&#40;&#41;
function OnNewOperation&#40;&#41;
   post.Text &#40;" &#40;Operation&#58; ", operationName, "&#41;\n"&#41;
   if &#40;plungeRate <= 0&#41; then
      post.Warning&#40;"WARNING&#58; Plunge rate is zero"&#41;
   if &#40;feedRate <= 0&#41; then
      post.Warning&#40;"WARNING&#58; Feed rate is zero"&#41;
function OnToolChange&#40;&#41;
   post.Text &#40;" &#40;tool number&#58; ", tool ," "&#41;
   post.Text&#40;" Feedrate&#58; ", feedRate * scale , "&#41; \n"&#41;
    if&#40;dthcOff == 0&#41; then
      post.Text &#40;" &#40;DTHC has been disabled in this tool&#41;\n"&#41;
      if&#40;presetVolts&#41; then
         post.Text &#40; "&#40;Preset Volts&#58; ",presetVolts," " &#41;
	  else
	  post.Text &#40;"&#40;"&#41;
      if&#40;presetAmps&#41; then
         post.Text &#40; " Preset AMPS&#58; " ,presetAmps,"&#41; "&#41;
		 post.Eol&#40;&#41;
		 else
		 post .Text &#40;"&#41;"&#41;
		 post.Eol&#40;&#41;
	  if&#40;presetPSI&#41; then
	     if&#40;presetPSI >0 &#41; then
            post.Text &#40; " &#40; Air Pressure Preset&#58; " ,presetPSI,"&#41; "&#41;
			post.Eol&#40;&#41;
		 else
		    post.Text &#40; " &#40; Default Air Pressure"&#41;
			post.Text &#40; "&#41;"&#41;
			post.Eol&#40;&#41;
      if&#40;tipSize&#41; then
	     post.Text &#40; "&#40; Suggested Tip Size&#58; " ,tipSize," "&#41;
		 else
		 post.Text &#40; "&#40;"&#41;
      if&#40;dthcDelay&#41; then
	    if&#40;dthcDelay > 0 &#41; then
          post.Text &#40; "  DTHC Delay&#58; " ,dthcDelay," sec &#41; "&#41;
		  post.Eol&#40;&#41;
	      else
	      post.Text &#40; ", Default DTHC Delay &#41;"&#41;
		  post.Eol&#40;&#41;
	else
	post.Eol&#40;&#41;
   if &#40;toolClass == "MarkerTool"   &#41; then
      ThcOff&#40;&#41;
      if&#40;scriberAxis and scriberAxis ~= currentZAxis&#41; then
         endZ = safeZ
         OnRapid&#40;&#41;
         currentZAxis = scriberAxis
      firstRef = true
   else --tool is not a marker
      if&#40;scriberAxis and scriberAxis == currentZAxis&#41; then
         endZ = safeZ
         OnRapid&#40;&#41;
         currentZAxis = "Z"
	     post.Text &#40;" S999 \n"&#41;
	 else
		 post.Text &#40;" S900 \n"&#41;
	    if&#40;presetVolts&#41; > 0 then
	     post.Text &#40; " S3" ,presetVolts, "\n" &#41;
		 post.Text &#40;"  M22 "&#41;
		 post.Eol&#40;&#41;
      else
         post.Text &#40; "&#40;No Preset Volts&#41;\n" &#41;
	      if&#40;presetAmps > 0&#41; then
	      post.Text&#40; " S4" ,presetAmps, "\n"&#41;
		  post.Eol&#40;&#41;
           else
         post.Text&#40;"&#40;No Preset Amps&#41;"&#41;
         post.Eol&#40;&#41;
	     if&#40;presetPSI > 0&#41; then
	         post.Text&#40; " S8" ,presetPSI, "\n"&#41;
		     post.Eol&#40;&#41;
         else
            post.Text&#40;"&#40;Default Air Pressure&#41;"&#41;
            post.Eol&#40;&#41;
           post.Text &#40; " S5"&#41;
		   post.Number &#40;dthcDelay * 10, "00"&#41;
		   post.Eol&#40;&#41;
      offX = 0
      offY = 0
      offZ = 0
	post.Text &#40;" M00"&#41;
	post.Text &#40;"&#40;Check the DTHC Settings  Hit RUN to continue&#41;\n"&#41;
	end --end for marker if
end --end for toolchangefunction
-- OnRapid&#40;&#41;
-- end
function OnNewPart&#40;&#41;
   post.Text&#40;" &#40;Part&#58; ",partName,"&#41;\n"&#41;;
function OnDrill&#40;&#41;
   OnRapid&#40;&#41;
   OnPenDown&#40;&#41;
   endZ = drillZ
   OnMove&#40;&#41;
   OnPenUp&#40;&#41;
   endZ = safeZ
   OnRapid&#40;&#41;
Having a lot of points would create a large nc-file.
I’d add a sub-program call in the pp and write the gcode vmax shows into that sub-prog.
Richard
Hi Richard,
sub-program call ??? :open_mouth:
How / where exactly do I write that gcode and call it? :blush:
Thanks.
A sub program does save space but Mach can handle huge files so it is a bit of a moot point. Try this version of OnDrill():
   if toolClass == "MarkerTool" then
      local ex = endY
      local ey = endY
      local siz = 6 / 2 --cross size is 6mm
      endX = ex + siz
      OnRapid&#40;&#41;
      OnPenDown&#40;&#41;
      endZ = cutHeight
      OnMove&#40;&#41;
      endX = ex - siz
      OnMove&#40;&#41;
      OnPenUp&#40;&#41;
      endZ = safeZ
      OnRapid&#40;&#41;
      endX = ex
      endY = ey + siz
      OnRapid&#40;&#41;
      OnPenDown&#40;&#41;
      endZ = cutHeight
      OnMove&#40;&#41;
      endY = ey - siz
      OnMove&#40;&#41;
      OnPenUp&#40;&#41;
      endZ = safeZ
      OnRapid&#40;&#41;
      return
   OnRapid&#40;&#41;
   OnPenDown&#40;&#41;
   endZ = drillZ
   OnMove&#40;&#41;
   OnPenUp&#40;&#41;
   endZ = safeZ
   OnRapid&#40;&#41;
This is untested but unless I’ve made a silly mistake it should mark a cross whenever you use a drill operation with a scriber tool.
Thank you so much, I will try this one! :smiley:
I just run a test job, your OnDrill() version works, I love the solution to use drill operation with plate marker,
no more extra sketching in CAD…
  1. yes, there is a small typo on second line in function:
    "local ex = endY " should be “local ex = endX
    before correction - plate marker performed nonsense. :open_mouth:
    DONE.
  2. now, the intriguing part is when plate marker goes for the very FIRST HORIZONTAL line
    on the first cross mark - it does it TWICE, back and forth on the same line, then moves on
    and continues fine on next cross marks… Why ???
UPDATE minutes later:
I just run it again, watched it closely and realized, that marker does not repeat the initial line in first cross twice,
but starts in the middle of the first hole, goes 3mm right, then 6mm left and so on…
Thank you again for your help.
Sample job:
Result gcode:
N0010 &#40;Filename&#58; mk part 01, 50x50mm sqare, 4x  5mm hole.tap&#41;
N0020 &#40;Post processor&#58; &#91;MK&#93; DREMEL-DRILL-MP3000-DTHCII-DCC+scriber6.scpost&#41;
N0030 &#40;Date&#58; 27/04/2015&#41;
N0040 G21 &#40;Units&#58; Metric&#41;
N0050 F1
N0060 G53 G90 G40
N0070 S10 &#40;DTHC is off&#41;
N0080 &#40;Part&#58; mk part 01, 50x50mm sqare, 4x  5mm hole&#41;
N0090 &#40;Operation&#58; Drill, holes, T100&#58; Scribe, Dremel - MK, 0 mm Deep&#41;
N0100 &#40;tool number&#58; 100  Feedrate&#58; 500&#41;
N0110&#40;&#41;
N0120&#40;&#41;
N0130 G00 X10.0000 Y10.0000 Z10.0000
N0140 X13.0000
N0150 G28.1 Z3.00 F1000.0
N0160 G92 Z0.0
N0170 G00 Z0.0000
N0180 G92 Z0.0
N0190 Z14.0000
N0200 X-78.1000 Y42.8000
N0210 M08
N0220 G04 P0.5
N0230 M22
N0240 G01 X-75.1000 F500.0
N0250 X-81.1000
N0260 M09
N0270 G04 P1
N0280 G00
N0290 X-78.1000 Y45.8000
N0300 M08
N0310 G04 P0.5
N0320 M22
N0330 G01
N0340 Y39.8000
N0350 M09
N0360 G04 P1
N0370 G00
N0380 X-75.1000 Y72.8000
N0390 M08
N0400 G04 P0.5
N0410 M22
N0420 G01
N0430 X-81.1000
N0440 M09
N0450 G04 P1
N0460 G00
N0470 X-78.1000 Y75.8000
N0480 M08
N0490 G04 P0.5
N0500 M22
N0510 G01
N0520 Y69.8000
N0530 M09
N0540 G04 P1
N0550 G00
N0560 X-45.1000 Y72.8000
N0570 M08
N0580 G04 P0.5
N0590 M22
N0600 G01
N0610 X-51.1000
N0620 M09
N0630 G04 P1
N0640 G00
N0650 X-48.1000 Y75.8000
N0660 M08
N0670 G04 P0.5
N0680 M22
N0690 G01
N0700 Y69.8000
N0710 M09
N0720 G04 P1
N0730 G00
N0740 X-45.1000 Y42.8000
N0750 M08
N0760 G04 P0.5
N0770 M22
N0780 G01
N0790 X-51.1000
N0800 M09
N0810 G04 P1
N0820 G00
N0830 X-48.1000 Y45.8000
N0840 M08
N0850 G04 P0.5
N0860 M22
N0870 G01
N0880 Y39.8000
N0890 M09
N0900 G04 P1
N0910 G00
N0920 &#40;Operation&#58; Outside Offset, final, T14&#58; Steel&#58; 2 mm, tip&#58; 40A, 108V - from TD manual&#41;
N0930 &#40;tool number&#58; 14  Feedrate&#58; 2239&#41;
N0940&#40;Preset Volts&#58; 108 &#41;
N0950&#40; Suggested Tip Size&#58; 40 , Default DTHC Delay &#41;
N0960 S900
N0970  M22
N0980 S3108
N0990  M22
N1000 M00&#40;Check the DTHC Settings  Hit RUN to continue&#41;
N1010 G00 X53.9500 Y-3.2000
N1020 Z4.1000
N1030 G28.1 Z3.00 F1000.0
N1040 G92 Z0.0
N1050 G00 Z0.0000
N1060 G92 Z0.0
N1070 G00 Z4.1000
N1080 M03
N1090 S20 &#40;DTHC is on&#41;
N1100 M22
N1110 G02 X50.7500 Y0.0000 I0.0000 J3.2000 F2239.0
N1120 G01 Y50.0000
N1130 G03 X50.0000 Y50.7500 I-0.7500 J0.0000
N1140 G01 X0.0000
N1150 G03 X-0.7500 Y50.0000 I0.0000 J-0.7500
N1160 G01 Y0.0000
N1170 G03 X0.0000 Y-0.7500 I0.7500 J0.0000
N1180 G01 X50.0000
N1190 M05
N1200 G00 Z10.0000
N1210 X0.0000 Y0.0000
N1220 S900
N1230 M22
N1240 S10 &#40;DTHC is off&#41;
N1250 M22
N1260 M05 M30
Sorry about the typo. The odd first mark is happening because I didn’t take referencing into account. This should fix it:
      local ex = endX
      local ey = endY
      endX = ex + siz
      OnRapid&#40;&#41;
      currentX = endX
      currentY = endY
      OnPenDown&#40;&#41;
Thank you!
Just tested, this one is flawless! :mrgreen:
Very very useful… we deserve a beer now…
For anyone else tired of drilling after plasma pierced holes,
here is the OnDrill() function crafted to perfection by Les Newell:
      local ex = endX
      local ey = endY
      endX = ex + siz
      OnRapid&#40;&#41;
      currentX = endX
      currentY = endY
      OnPenDown&#40;&#41;
      endZ = cutHeight
      OnMove&#40;&#41;
      endX = ex - siz
      OnMove&#40;&#41;
      OnPenUp&#40;&#41;
      endZ = safeZ
      OnRapid&#40;&#41;
      endX = ex
      endY = ey + siz
      OnRapid&#40;&#41;
      OnPenDown&#40;&#41;
      endZ = cutHeight
      OnMove&#40;&#41;
      endY = ey - siz
      OnMove&#40;&#41;
      OnPenUp&#40;&#41;
      endZ = safeZ
      OnRapid&#40;&#41;
      return
   OnRapid&#40;&#41;
   OnPenDown&#40;&#41;
   endZ = drillZ
   OnMove&#40;&#41;
   OnPenUp&#40;&#41;
   endZ = safeZ
   OnRapid&#40;&#41;
As a thought would it not be better to create the entire X mark in one operation rather than breaking it up into 2 functions. Lower the scribe one time run the X code then raise the scriber.
As is you are lowering the scriber , scribe one line then raise the scriber , then lower the scribet again to do the next line.
You may also want to adjust the feedrate for the scribing.
Just a thought, (:wink: TP
As it is done at the moment, that’s exactly how I wanted the function to behave…
Two clean separate precise lines with fine marker tip without extra sketching in cad.
Version of cross mark in one pass looks little different - as you gotta follow part of it twice of course.
Cheers.
Thank you Vmax,
I didn’t expect anybody here except Les pays proper attention to code sections, I appreciate it. :slight_smile:
What feedrate (metric of course) for scribing do you suggest from your own experience?
Especially for precise cross marks and bend lines - that’s what I care about most…
I tried 1000, seems little nicer so far…
Also, to be super honest:
I consider plate marker to be most painful part on plasma table and I am not talking about number
of demo videos on youtube, people showing off their logos, artwork, some serial numbers on parts etc.
Painful because: once you install that vicious bugger on your gantry it will show you almost EVERYTHING you messed
on the table as a “mechanical engineer” - not that I am one…
Suddenly all minor details matter once you expect plate marker to position proper center marks, bend lines, marks for alignment etc.
Even for the smallest “play” in Z axis you WILL be punished, magnetic break-away torch holder will teach you a lesson,
you will finally understand the practical meaning of the word “backlash”, you will appreciate linear guides - which you did not use,
the fact you didn’t need gantry squaring until now and list goes on and on…
All you gotta do is to let the scribe to “draw” you a large square (1x1m) which resembles measuring tape on all sides,
then compare the result with precision steel rule (make sure you are alone in the shop) and let it amuse you… :laughing:
Bottom line:
From my experience, I like to call the precision plate marker on your plasma table a “truth teller”… :open_mouth:
It will open your eyes, make you a better fabricator and if you are serious about your business - it may force you to
build another table where you WILL pay attention to all details…
Anyways… I’m done for tonight - no more sheet metal stories, till next time. :wink:
